wiring which goes where
Postby Ron Dickey » Sun Oct 29, 2006 1:19 pm
I know I know but do I.
I got the wires in and was attaching the brown wire which are the marker lights.
Then as I got to the stop lights and blinkers which had the colors needed coming from the lights.
I had looked at the drawing that came with the lights over and over and over but I must have been checking to see which as the blinker stop and which where the markers, and not where the front was and the back or which was left and which right.
So If you are not watching you could :crazy: not have your trailer say you are turning in the oposite direction and then I would have a different story to tell. :crying2: :BE :DOH2: a real no no :shocked: :oops:
you Tell them folks which goes where is there a rim or saying that helps one remeber which goes where
something like
if it is green right as soon as you can
when turning left be more mellow look for yellow
Fixed I was a little embarressed now I really am :oops: :cry: now that you all know I know you will under stand :noyes:
173882......173887
Ron Dickey
Images: 787
Postby Dale M. » Sun Oct 29, 2006 5:37 pm
THis is the industry "typical" wiring scheme for trail lighting...
Assuming here that you are using traditional flat four wire....
Dale
Dale M.
Images: 18
