Tractor Supply 4 FT. X 8 FT. CARRY-ON TRAILER
Postby cwm » Thu Nov 16, 2006 11:51 pm
Has anybody used the Carry-On 4x8 trailer from tractor supply? How does it compare to the HF and Red trialers?
http://tractorsupply.com/detail.asp?pcI ... ctID=17492
cwm
Postby sdtripper2 » Fri Nov 17, 2006 12:59 am
Model SKU #1000215 2,000 lb GVW
This Trailer is one of the 5 most touted trailers on this forum cwm.
However you could look at these threads from the forum to reflect on
some opinions of the past. http://tinyurl.com/o3tzh
*These trailers can be ordered in other sizes too if you can find a
co-operative sales person. The key here is that many threads
hint at trouble getting quotes or the right person to help you.
Read the threads above please before you buy.
I am sure there will be others along to give you their experiences as well~
sdtripper2
Search Garoux
Images: 168
Postby len19070 » Fri Nov 17, 2006 6:09 am
The TS trailer is a nice trailer, I bought several last year for my 2006 model. The problems I have with them are their not a precision piece of equipment. By this I mean these trailers were designed to be utility trailers for someone to just throw a piece of 4X8 plywood in the channel and go. And that's exactly what they are. A sheet of plywood fits in there real easy, with out cutting it. With a 1/2" gap at one end, 3/8" on one side then at the other end its 1/2", then 1/4. By the time your done you've got a 49-49 1/2" wide trailer that's 97" long. And that's not 4X8.
Here's a link sent to me by another member.
http://www.butterfoot.com/teardrop.htm
That being known..I'd still use them again.
Now the HF trailer can be narrowed to 46 1/2 (or what ever) for a trailer body that covers the frame. And I see now where there coming with 5 lug wheels.
Happy Trails
Len
len19070
Images: 24
Postby Kens » Fri Nov 17, 2006 1:05 pm
TSC trailer worked fine for me but I built over the fenders alittle. :thumbsup:
Good day every day!
Kens
Images: 26
Postby len19070 » Fri Nov 17, 2006 6:16 pm
Thats what I mean Kens. As long as you build over the frame...its fine. Its just not a 4X8 frame. Other than that, its a great frame.
Happy Trails
Len
len19070
Images: 24
Postby surveytech » Fri Nov 17, 2006 6:28 pm
one advantage to the TSC trailer is the bearings & seals are standard and not metric.
That makes it easy to find replacements when needed.
surveytech
Images: 6
Postby halfdome, Danny » Fri Nov 17, 2006 8:00 pm
When I was looking for a chassis for my tear I was real interested in the same trailer. My neighbor had one for sale that would have worked but he talked me out of it when he stated that the single tube tongue shimmied a lot when towing. I now have the "A" frame type tongue on my tear. They have similar trailers at Home Depot & Lowes and the tongue is bolted on, it may be OK for some but not me. IMHO :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby cwm » Fri Nov 17, 2006 10:02 pm
Thanks for the input guys.
cwm
Postby surveytech » Sat Nov 18, 2006 7:42 pm
The TSC trailer tows super smooth at 75 mph....real nice.
surveytech
Images: 6
Postby asianflava » Sat Nov 18, 2006 7:56 pm
halfdome, Danny wrote:[color=blue][b] My neighbor had one for sale that would have worked but he talked me out of it when he stated that the single tube tongue shimmied a lot when towing.
I'll confirm that! Yes, mine shimmys when I hit bumps but I've learned to live with it. It was a little unnerving at first. I still like the looks of the single tube tongue. I suppose if it was made of stiffer material, say a 3x3 tube instead of a 2x2, it would fix the problem.
asianflava
Postby cwm » Sun Nov 19, 2006 1:47 am
Does anybody know what the wall thickness is on that 2x2 tube? I think the problem is that the cross bar that ties the tonge to the frame is too flimsy and maybe the 2x2 tube is not thick enough.
cwm
