You wrote:I was just checking out the red trailers site and noticed that they have a new 5x10 black trailer with 13" tires. They are taking pre-orders with a $100 deposit with delivery expected in late January. Since I am pretty sure that I want to build a 5x10 trailer I think this might be a good option.
I am assuming that this model SJ-8535 will not be a folding trailer, does anybody know?
DougH wrote:I was thinking about one of these, like the 13" wheels and non folding. I did notice that bed width is listed as 61" and am wondering why they went wider than 5'? If it was made for a treardrop why didn't they make it
58- 59"?
Was thinking about a Benroy profile, any ideas about the extra 2'? Would it be better to lengthen the body by two feet for more cabin space or use the standard 8" profile with maybe a full width storage box in front? Of course I could just get the 5 X 8 but that has 12" wheels.
sdtripper2 wrote:You wrote:I was just checking out the red trailers site and noticed that they have a new 5x10 black trailer with 13" tires. They are taking pre-orders with a $100 deposit with delivery expected in late January. Since I am pretty sure that I want to build a 5x10 trailer I think this might be a good option.
Model SJ-8535 — 5' x 10' Frame with 13" Tires
The price of this trailer will be $599.95.
SJ-8535 Specifications & Pre-Order Information: "Clicky"
cwm:
Your answer: This trailer has a solid frame~
Frame:
* One-Piece Bed
* 2" x 3" x 2.5mm Tube Frame Structure
* 2" wide x 3" high Tongue
* Durable Black Powder Coat Enamel Finish
Email reply from Red Trailer:
Paul Hetrick
[email protected]
Hello Steve,
All the specifications are on our web-site at www.redtrailers.com. The
trailer only comes in black. This is a solid trailer not a folding trailer.
And we are taking deposit on our first load of these trailers that will be
in January.
Thanks www.redtrailers.com
Hope this helps cwm, what is your name again?
Dimensions:
Bed Structure - 61" x 118"
Deck to Coupler Clearance - 60"
Coupler Height When Level - 18"
Length from Rear Crossmember to Coupler - 177"
Overall Width Including Fenders - 79"
Weight of Trailer - 415 lbs.
Max Load Capacity - 1585 lbs.
Axle - 1.75" Square Tube Steel
4-Leaf Axle Springs
Gross Axle Weight Rating - 2000 lbs. Using Supplied Tires & Rims at 60 PSI Cold
Gross Vehicle Weight Rating - 2000 lbs.
Lighting:
D.O.T./C.S.A. Compliant Stop, Turn, Tail & Running Light Assemblies
D.O.T./C.S.A. Compliant Amber Running Lights
4-Flat Trailer Wiring Connector
16 Ga Wire Throughout
Coupler:
2" Latch Closure Steel Coupler
Class II, 2000 lbs Max Rating
Bolt-On Safety Chains
Recommended Accessory: Coupler Lock
Frame:
One-Piece Bed
Tires:
Painted 13 x 3.75 Steel Rims
5-Bolt EasyLube Hubs
175 x 80 D 13 6-Ply Tires
