angib wrote:The data I've received is that the 1800lb HF trailer has a 2.25"x1.5"x11g(0.12") channel section frame and that is shown on my Tongue Strength page - it has a vertical strength that's a little bit more than a 2"x2"x14g(0.083") square tube.
However I've also seen reports that the tongue members of the 1800lb frame are actually a C-section, where the flanges curl back in on the 'open' side, which would make them quite a bit stronger.
With all you guys with HF trailers, surely there's someone who can accurately measure theirs?
Andrew
Wangofree wrote:
My other question, looking at the instruction manual, I'm wondering if any fellas substitute the included metric bolts with some heavy duty stainless steel bolts or does anyone actually have these trailers welded up for extra strength?
So a simple box frame of 2 X 2 by 1/8th steel would be considerably stronger than an 1800 lb Harbor Freight trailer frame?angib wrote:The data I've received is that the 1800lb HF trailer has a 2.25"x1.5"x11g(0.12") channel section frame and that is shown on my Tongue Strength page - it has a vertical strength that's a little bit more than a 2"x2"x14g(0.083") square tube
Arne wrote:
bdosborn wrote:I wouldn't use stainless steel bolts as they are usually ungraded and not very strong. I built my trailer twice, once with the bolts that came with the trailer and then again with grade 5 bolts and washers. The frame was *much* stiffer with grade 5 bolts. Some people have welded their HF frames but I think most of us are pretty happy with it bolted together.
steve wolverton wrote:Arne wrote:
Wow! What are the odds of your camper sliding to the side of the road where barricades were already set up? How lucky was that!
Wangofree wrote:I'd like to interject a couple of things. I don't think HF offers the HF model 40597 ITEM 40597-0VGA HF 1800 LB trailer anymore. I've searched and couldn't seem to find it. HF says it's "discontinued". I believe the only alternative left is the 1740lb 4 x 8 Model 94564. I suppose this trailer will make an adequate frame for a tear.
My other question, looking at the instruction manual, I'm wondering if any fellas substitute the included metric bolts with some heavy duty stainless steel bolts or does anyone actually have these trailers welded up for extra strength? Is there enough steel to get a good weld, in addition to the bolts that are used for fabrication?
I'm planning on building this after my wife's 2 other projects, a carport and patio cover....so, in about 3 years, maybe.![]()
Thanks.....Mike
bdosborn wrote:[]
