Steve B:
I have the Dexter on my trailer and it is a standard trailer axle #9. I pull
with a Honda CR-v and my trailer empty is about 800lb and about 1k- 1100lb
full. The tow is smooth as glass and have no jumping or bumping of the
trailer at all.
Really don't have the perspective of a perfect matched axle to weight, but
you might be splitting hairs. The MadOne usually has good advice as do
many here that have chosen the customized axle. If you go with the
anticipated weight plus some 50% and have them tune your axle to that
you will most likely be very happy. Jack and the guys speak from
experience and that counts. Remember build lite for all the right reasons
and your axle and wallet will thank you in many ways.
Your Teardrop should be able to be pulled around with ease by one person.
The right weight placement as in
Andrews vision of tear time balancewill
make your experience more pleasurable.
Mine TD is a pleasure to manipulate even in sandy conditions, however a
better wheel uP front would be better than a stock wheel on the jack.
Be daring Steve ...
Best wishes,
Tripp-Out
