Need help with choosing a trailer
Postby Gringo Loco » Wed Jul 11, 2007 10:20 pm
Hello all, I am trying to decide whch trailer to buy for my weekender buildup. I am torn between the NTE 5x8 trailer for $299 or the red trailers 5x8 SJ-8534 for $530. I like the design of the RT because it is not angle iron but if I go for the NTE trailer I can also get wood for the build. Does any one have any thoughts, I want to do this right the first time so all input is appreciated.
Thanx
Chris
Gringo Loco
Images: 27
Postby sdtripper2 » Wed Jul 11, 2007 11:19 pm
Chris:
Will you be pulling this trailer off road?
Will you want standard tires say 15" or will you be happy with smaller tires
that many trailers have?
sdtripper2
Search Garoux
Images: 168
Postby Gringo Loco » Thu Jul 12, 2007 12:06 am
I won't be using it to go off road. I can deal with 12-13" wheels and later I could upgrade axles if needed. One thing is that my liberty is lifted, would this cause any problems?
Chris
Gringo Loco
Images: 27
Postby sdtripper2 » Thu Jul 12, 2007 12:25 am
Chris:
Visualize a level trailer as it attaches to your Tow Vehicle (TV).
That is to have when all is said and done a trailer that appears to ride even, behind your TV.
If your TV hitch receiver is high:
So you can either lower axle on bottom of springs to put trailer frame higher,
use larger tires, or use small tires and manipulate the tow-bar to have the
ball lower to accommodate the trailer so as to make the visual flow str8.
Some may do all of the above~
If your TV hitch receiver is low:
You would look at the above receiver high list and make changes
accordingly in planning or after completion.
Some reading:
Red Trailer ride height? Above or Below the spring distances
Many decisions on trailers
http://tnttt.com/viewtopic.php?p=140446
Trailer hitch decisions and measurements & Pictures
http://www.accessconnect.com/trailer_to ... h_ball.htm
sdtripper2
Search Garoux
Images: 168
Postby Gringo Loco » Thu Jul 12, 2007 1:48 pm
Thanx Steve
Chris
Gringo Loco
Images: 27
Postby jagular7 » Fri Jul 13, 2007 11:02 pm
Have you been to the L.O.S.T. forum (http://www.lostkjs.com/forum/phpBB2/). Lots of Liberty owners with info/exp with lifted/nonlifted, pulling trailer, etc.
There you can get an idea to a hitch frame height, but that will also depend on your choice of hitch frame or the integrated rear bumper setup.
I believe the Liberty can pull up to 3000#s un-optioned. With towing options, it could possibly go up to 5000#s. Biggest concern will be the availability of gear ratios to match the tire size to the performance of the lifted Liberty, then to pull a trailer.
Anyways, check over the Liberty specific forum. For a trailer frame, I'd prefer a box outer frame, but if you look at how the older pop-up campers are designed (similar weight and overall box size to a TD), the frame is really light and the floor adds structure to the assembly.
Mike
Jagular
Lenexa, KS
jagular7
Postby Gringo Loco » Sat Jul 14, 2007 12:19 am
Hey Mike, I am on L.O.S.T. daily and have been for the last two years :? . We really don't have a trailer section but I know of a couple of guys to ask about the questions I have.
Thanx
Chris
Gringo Loco
Images: 27
Postby jagular7 » Sat Jul 14, 2007 10:19 pm
To tell you, you are a little better off than me. I've got a 4cyl/auto 97 TJ, lifted, running 35's, with 4.88/lockers in the axles. Without an engine swap, I'm no faster than the diesel Rabbit of yesteryear. Then think about pulling a camper along....
There are a couple other wheeler owners on this forum. Few are even in different parts of the world.
To keep the Jeep-utility theme, I've got a Pingauer ambulance box for a conversion to a camper (http://www.tnttt.com/viewtopic.php?t=16422). Its similar size as a Compact II (120" long, 70" wide, 70" tall). I'm placing it on a M101 trailer mod'd to work with the longer camper.
Mike
Jagular
Lenexa, KS
jagular7
