by angib » Wed Aug 01, 2007 11:24 am
OK, this tongue needs to be checked twice - once at the back end of the single tongue and once more at the back end of the composite (3-piece) tongue.
Front, solo tongue: 2"x2"x1/4" gives 25,300 lb-in capacity, so with a 34" tongue that gives an Aussie GVWR rating of 1,490 lb - I reckon it's safe to double this for a well-balanced trailer, so that's around 3,000 lb. No strength problem there, as long as the receiver mount is equally strong.
Main, 3-piece tongue: Are all three pieces made of 2"x2"x1/4"? If so, that would give a 75,900 lb-in capacity. Total tongue length is 36"+34"=70" so you get an Aussie GVWR rating of 2,170 lb - which is probably safe up to 4,000 lb.
Andrew
