James, there are indeed, 2 sets of bearings...inner and outer...removing the inner bearings can be tricky since it requires the removal of the inner grease seal...this seal is easily damaged and if damaged, it will havvta be replaced...it is an oddball metric size and may not be easily found
...2 of the easier ways to proceed...
1)...after removing the outer bearings, put the castle nut back on and see if it will go into the hub, past the bearing race
...if so pull the whole hub off and the inner bearing and seal should be left hanging on the spindle
...remove castle nut, bearing and seal and clean bearing(I still use gas)...repack bearing and carefully reassemble bearing and seal in hub, replace on spindle
2)...if castle nut will not fit, remove hub
...bearing and seal will still be in the hub
...use an appropriately sized wooden dowel or a drift pin(preferably brass/bronze) to carefully, punch out bearing/seal from the inside out
...DO NOT use a screwdriver to pry the seal out from the back, as this will probably destoy/damage the seal
...after bearings are removed clean/repack/reassemble
...GOOD LUCK and BE CAREFUL......
