frame
frame
Postby Mr_k QLD » Thu Sep 20, 2007 5:04 am
Im thinking of building a 4' x 8' light weight camper using around 5/8 ply aluminium covered camper
the steel im thinking of 1" x 2" x 2mm???? (I don't know how to convert that lol) with a 48" tongue
what do you think
regards Adrian
P.s. If I could work out how to put a pick on here i would scan my design so you could see it
Mr_k QLD
Postby ARKPAT » Thu Sep 20, 2007 5:18 am
Adrian;
If you can you might fax/scan a sketch or hand drawn drawing to Mike and PM him or one of the Admin.'s and have the convert it. for you.
:thinking:
I'm sure some one else will be in here in a little while with some help.
I hope this will help. You might check with Paul C also how or where to get your picture scanned or to fax it.
G-day
Pat
ARKPAT
Images: 77
Postby PaulC » Thu Sep 20, 2007 5:47 am
Thanks Pat. Adrian has my e-mail address now so that should'nt be a prob for him.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
body shaping
Postby Mr_k QLD » Thu Sep 20, 2007 6:16 am
Yeh thanx for that Pat & Paul hope to here for you more often
Ok here is my next question?
If I round off the front & back of the body do I just shorten the chassis frame so it still sits under the body?
regards Adrian
Mr_k QLD
Re: body shaping
Postby PaulC » Thu Sep 20, 2007 6:23 am
Mr_k QLD wrote:Yeh thanx for that Pat & Paul hope to here for you more often
regards Adrian
That's exactly what I did Adrian. I made a 300mm radius curve and the bottom corners and shortened the chassis to suit.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
final thoughts
Postby Mr_k QLD » Sat Sep 22, 2007 5:35 am
Ok I have had a good think about it and have chatted to a trailer builder over here in australia
The chassis under the body of my TD I will build out of 2" x 1"
The A bar will be made of 2" x 2" and it will be 4' so I can add a storage/battery box on it
i have tried to work out how to up load a couple of scans of the diargram :? but i recon that will be another time lol
well sounds like a plan
what does every body think
adrian
Mr_k QLD
Postby PaulC » Sat Sep 22, 2007 5:57 am
Chassis 50x25x2.5
A Frame 50x25x3 with under bracing.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
