jimqpublic wrote: ...............Question for the experts: Dexter shows the #9 as spanning 1000 to 2200 pounds, and the #10 from 2300 to 3500. If you order a #10 and specify that it will be used for 2300 pounds GAW do they cut the rubber short to give an appropriately soft ride?
Section 8 wrote:For the poster who mentioned not being able to lock the brakes, I asume that this was on pavement? Have you tried hitting the brake controller to see how mch power they have? Are they really weak?
Section 8 wrote:... with my remedial understanding of surge brakes, they won't work backing down a hill...
Section 8 wrote:... and they wil tend to push the jeep more and more the farther from following directly behind the jeep the trailer is when you apply the brakes since it has to push on the ball to actuate the brakes. The farther the trailer is off center, the closer it is to being jack knifed already, adding a rotation to the jeep that will aid this in occuring doesn't sound like a good idea...
Alphacarina wrote:After several lengthy discussions with an engineer at Dexter when I was building my boat trailer, they don't recommend you to use torsion axles unless the axle capacity is pretty near the loaded weight of the trailer. I was considering whether to use 2 or 3 of their 5500 pound axles and when we discussed my maximum weight (~8,000 pounds for the boat and ~3,000 pounds for the trailer) they strongly advised me to go with just 2 axles, as adding a third posed several problems, one of which was that it would ride terribly because the load wasn't heavy enough for 3 axles rated at a total of 6,500 pounds. 11,000 loaded pounds for 2 5500 pound axles was considered as 'perfect' by the engineer
