widening hf axles
widening hf axles
Postby satch » Wed Feb 13, 2008 8:54 am
I've been going over some old posts on widening hf axles, the ones I have found are a few years old, so I was wondering if anyone has done this with the 1800#(round axle) with any success.
If it itches. scratch it
Rick
satch
Images: 63
Postby madjack » Wed Feb 13, 2008 9:46 am
...not sure about the 1800# axle but "Jim Marshall" did a great job on widening his axle http://tnttt.com/album_ ... C&start=48
Postby angib » Wed Feb 13, 2008 10:43 am
Just remember that you can safely widen the axle in the middle - so that the wheels don't overhang the springs any more than they did before.
What you can't (safely) do is widen the axle by increasing the overhang - ie, leaving the spacing between the springs unchanged.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby satch » Wed Feb 13, 2008 7:36 pm
Thanks for posting back, MJ, I have looked at Jim's photos, and was planning something similar, the only differance is, he has a square axle, and mine is round.The dia. of mine seems to be a hair under 1 3/4"(metric?) Iwould have to find some tube stock that would work. :x
Rick
satch
Images: 63
Postby doug hodder » Wed Feb 13, 2008 8:55 pm
Is it possible to cut the spindles out of the axle and just get a new tube? I've built axles like that before. They don't have the bridge built into them, but it may be easier than trying to align everything for the weld-up. Just a thought. Doug
Postby satch » Wed Feb 13, 2008 9:22 pm
Not sure if that's possible, I thought I would cut it in half and "sleave" it with another tube. I have a tube, but don't know if it will fit.(the trailer is assembled, going to DMV on fri.) My crude measurements say it might be to big(axle)
Rick
satch
Images: 63
Axles
Postby HossHoffer » Wed Feb 13, 2008 10:34 pm
doug hodder wrote:Is it possible to cut the spindles out of the axle and just get a new tube? I've built axles like that before. They don't have the bridge built into them, but it may be easier than trying to align everything for the weld-up. Just a thought. Doug
I've seen it done. They cut the spindles from the axle leaving a little bit of the axle which were spliced to the new axle. Just as strong as cutting the axle in the middle.
Hoss
HossHoffer
Images: 7
Postby satch » Wed Feb 13, 2008 10:48 pm
Thanks for the input,Hoss, I will have to wait 'till this weekend to remove the axle and check the possiblities. You all have been great!!
Rick
satch
Images: 63
Postby Jim Marshall » Wed Feb 13, 2008 11:54 pm
Satch, if your axel is round you could weld angle iron from side to side on top and on the bottom of your axel. That would be a lot stronger than your axel is now.
I started out with nothing and I still got plenty left.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby satch » Thu Feb 14, 2008 12:29 am
Jim Marshall wrote:Satch, if your axel is round you could weld angle iron from side to side on top and on the bottom of your axel. That would be a lot stronger than your axel is now.
You mean "box it in with two pieces of "L" iron?
Rick
satch
Images: 63
Postby brian_bp » Thu Feb 14, 2008 7:29 pm
All of this fabrication sounds like a pile of effort for little benefit. How much does a new beam of the right width (with spindles, but not the springs or hubs) cost?
brian_bp
Images: 9
Postby satch » Thu Feb 14, 2008 8:08 pm
brian_bp wrote:All of this fabrication sounds like a pile of effort for little benefit. How much does a new beam of the right width (with spindles, but not the springs or hubs) cost?
$100.-150,I think,but I don't know if the hf hubs will work,and I hate to waste this axle, plus I just want to know how easy this would be, I may just build over the wheels
Rick
satch
Images: 63
Postby Jim Marshall » Thu Feb 14, 2008 11:27 pm
Yes, that is what I was talking about Satch.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby Tx River Rat » Fri Feb 15, 2008 11:03 am
Satch
The splice in the center is best and if you cant find a piece of tubing for the outside find one that fitts inside cut it long enough to extend inside the tube about 6 inches on each side weld and the plug weld it at about four inches.
I have done a jillion of them this way
Ron
Tx River Rat
2nd Teardrop Club
Postby satch » Fri Feb 15, 2008 7:32 pm
Tx River Rat wrote:Satch
Ron
That may be an option,but if the outer dia. is metric, I'm sure the inner is too, won't know untill I "hack" in two. The "L" box might be the only way. I don't know what you guys pay for steel, Here a 20' stick of 2" L angle goes for $45. :shock:
Rick
satch
Images: 63
