Alphacarina wrote:I would weld the plate on - You would be drilling a fairly large hole exactly where you don 't want it for strength purposes, plus it will allow moisture inside the axle which will eventually rust it out from the inside out . . . . you'll get no warning when one wheel is about to fall off
Don
BigDaddyCool wrote:because of condensation, hot and cold will make moisture in enclosed tubing...
