Leon wrote:... I use a weld-through coating on the steel before it is welded that does a pretty good job of protecting the metal yet allows a good weld.
Trackstriper wrote:I could seal off the tubing ends and weld on small mounting tabs for the floor attachment so that the tubes would not be pierced by screws. The tubes could be purged with dry nitrogen to eliminate moisture and reduce the oxygen. More work, but is it worth it?
brian_bp wrote:Leon wrote:... I use a weld-through coating on the steel before it is welded that does a pretty good job of protecting the metal yet allows a good weld.
Interesting... do you have a brand name to share with us, Leon?
Leon wrote:brian_bp wrote:Leon wrote:... I use a weld-through coating on the steel before it is welded that does a pretty good job of protecting the metal yet allows a good weld.
I use the stuff from 3M, it's available at some auto parts places, and most welding supply houses...
