dust seals
dust seals
Postby ADK » Sat May 24, 2008 5:27 am
In the process of re-packing my wheel bearings I have discovered two problems. The bearings themselves are pretty much standard size but the grease seals are not. Consequently the dust caps, which are non-existent are not a standard size either. I do not know the heritage of this trailer so I cannot go back to the manufacturer for info.
I think that NAPA can cross reference my seals (no markings on the seals.)but absolutely no luck on dust caps, any suggestions? The ID hub size mikes out to 2.0625"
Replacing the hubs is an option but only after all possibilities of finding replacement parts have been exhausted.
"Problems are only opportunities in work clothes." - Henry J. Kaiser
ADK
Images: 16
Postby Steve_Cox » Sat May 24, 2008 7:22 am
A 53mm dust cap might fit if the edge has enough of a taper to get it started. It is about 14 thousandths of an inch bigger than your hub opening. It is an older GM size.
Steve_Cox
Images: 196
Postby Kevin A » Sat May 24, 2008 10:13 am
Find someone with a lathe, have them open the ID of the hub to accept a slightly larger than original dust cap. I had to bore the hubs on my trailer for the same reason.
Kevin A
The other guy
Images: 289
Postby ADK » Sat May 24, 2008 4:18 pm
Thanks Kevin & Steve, I believe I have found a source that may have what I need and may also be useful info for others with the same issue. RedTrailer at http://www.redtrailers.com has a dust cap for 2.0625" hubs and grease seals for the same. I have not ordered yet, I am going to send an e-mail with my technical questions and see if in fact they are correct.
ADK
Images: 16
