I flipped my frame over today to finish the bottom side welds and guess what? I had managed to burn a small hole through the square tube right behind the axle mount plate on the corner of the tube. So...I backed off the power (AC stick) and tried building up enough bead to fill it, but that is not working. Now the hole is about 3/8" round.
Now what?
I have plenty of 1/8" angle iron. Should I weld a piece of that over the hole as a patch?
Should I through myself under a bus? Help!
Geoff
