by angib » Wed Jun 04, 2008 2:34 am
That looks like a good choice - I guess it might be made from 1/4" thick channel which would push its weight up, but apart from that it's probably the most sensible used trailer anyone has started with.
Moving the spring hangers, to get the balance right, is perfectly possible with a bit of grinding and a bit of welding, and access is so much better now that it would be better to get that sorted now rather than later. If it's a regular 8ft teardrop body you want, then having the axle 34-36" from the rear of the body, or at most 38", is recommended. If you won't carry much weight in the galley, you could even up that measurement by 2", though by then you may have to repack the teardrop for towing, putting any heavy stuff right at the front of the cabin to get the hitch weight safe.
49" between the tyres sounds just right if you want narrower tyres - at least 1" per side is a sensible clearance for a spring axle.
It's hard to tell, but it looks like this trailer didn't have a conventional coupler before, so it might take a bit of welding work to adapt it to take one - an ideal time to sort out the axle, if it needs it.
'Pipeline welder' trailer sounds like a description, not a trade name, to me - but then whadda I know, I'm a furriner...
Andrew
