From what I've seen, the dominant fad these days with teardrop builders is to build an absolutely rigid steel chassis out of 2" thick wall tubing and weld it all. The lesser fad is to get a many times lighter, bolt-together, C-channel steel, Harbor Freight trailer to carry the same size structure as the 2" square tube, overkill chassis.
You wouldn't believe how minimally they constructed the chassis of my 1956 Shasta trailer back in '56. Three full-length runs of two inch C-channel into an A-frame with a little 2-inch angle iron for cross members. I beefed it up slightly with bed frame angle iron and a couple of 5-foot trusses of square 1/2 inch rod underneath from the tongue to the front of the spring carriers. It's almost as rigid as a 2-inch, thick-wall, square tube at 1/4 the weight. The economy of weight to strength is important when you put it all in motion and the weight suddenly turns into momentum.
If you image google BOLUS TRAILER you can find a photo of one with the body removed and chassis up on oil drums. It's all 1" steel pipe trussed marvelously! THAT'S a weight-conscious design and it's rigid.
Prem
