The 940 pounds was what it weighed at the truck stop with bedding, etc. in it. The water tank was empty. It is true that lately, when I get into it ('I'm not QUITE 160 lbs) the trailer seems to flex and make a little protest sound, like a little "crack!"
Esteban wrote:A solid axle will not weigh as much as you fear. ...weighed about 104 pounds on a digital bathroom scale. . . I'd think a continuous torsion axle could probably be bolted to the same mounting plates. . .
