I know there's a rubber insert in the ends. I want to cut from the center and weld it back together. Setting it up to the original camber shouldn't be a problem. I'm just wondering about that rubber.
Any thoughts?
Steve Frederick wrote:Any thoughts?
If you ask the manufacturer, they'll tell you 'NO!' - What else CAN they say, since they have no control over how you'll do it or how good you can weld. They want to absolve themselves of ANY liability should something go wrong down the lineSteve Frederick wrote:I'm thinking about cutting 12" out of a Flexride 60" axle.
I know there's a rubber insert in the ends. I want to cut from the center and weld it back together. Setting it up to the original camber shouldn't be a problem. I'm just wondering about that rubber.![]()
Any thoughts?
