Adding Suspension - Ideas??? UPDATE
Postby Nor'East Coaster » Mon Mar 30, 2009 8:12 pm
"Friend of a friend" came by yesterday, and had a gander at the trailer - the short version re whether it's worth sorting it out is "...well, maybe, depending..." It'd need the solid axle removed, a leaf spring kit put under it, and assorted welding adjustments to accommodate mounting that. He also wasn't fussy about the axle stubs used - they're from the rear wheels of a front-drive car - but they can at least be unbolted and replaced - chucking a spare hub in the toolchest would take care of on-the-road failures. The springs and mounting hardware would cost about $100 Cdn., which is doable if it means we can use the existing axle, hubs and wheels...
If we can't, it gets prohibitive - a 3500 lb. axle runs about $225 more, and then there's wheels and tires to consider, not to mention labour - probably way better to sell this one and look around for something that's ready to roll. Since the basic 8x5 design is set, we can go ahead with some prefab work - build the sidewall, front, roof and rear panels - and work on the floor/base and how it'll be attached to the trailer.
(Just to put the icing on the cake, pack ice has blown into the bay, locked solid to the coast as far as the eye can see, with a nice 20 mph nor'easter blowing onshore after a hundred miles of moving over the icefields - you can literally smell the ice when you step outside, and it carries a very special sort of damp clammy cold that goes right to your bones...that's what you get for living on an island in the middle of the North Atlantic..)
Anyway, thanks for all the advice and encouragement thru the posts and the PMs. We'll keep you posted...
Know Your Boat, Know Your Waters, Know Your Weather and Your Limits
Nor'East Coaster
Images: 5
Postby Micro469 » Wed Apr 01, 2009 8:00 pm
This post gave me a chuckle, had to go back and read your other post about getting the trailer built. Really tho, I don't think you will have problems with the rear end of a front wheel drive car as long as the axle is straight. A couple of springs and you should be all set. If you do decide to buy a new axle, Why a 3500 LB? I think that would be overkill, unless you make the tear REALLY heavy. I would go with a 2000 LB, most tears don't weigh more than 1500 LB, alot of them weigh Way less.......Unless you overbuild like I did.....
I like Your Avatar with the Kayaks...Got any better closeups of the ones you build? Any more info??
John
Micro469
Images: 382
