Invention for Standies "The Skater"
Postby NightCap » Sun Jun 14, 2009 1:46 pm
Doug was mentioning how he might have trouble getting his trailer out of his garage because of height restrictions... then I thought of making something that would make it possible to make a taller trailer and still get it in and out of the garage. It was sort of a joke at first, however I think it has some merit. What do you all think?
http://www.mikenchell.com/forums/viewtopic.php?p=528896#528896
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby starleen2 » Sun Jun 14, 2009 2:09 pm
I'm thinking a few well placed stabilizer jacks in the front and back to raise the frame enough to take off the wheels - it would eliminate the need for a floor jack = they'll always be there when you need em' - just crank them down - take off the wheels - then crank them back up
starleen2
5th Teardrop Club
Postby aggie79 » Sun Jun 14, 2009 3:00 pm
If the length of your wheel studs were long enough, you could make a triangular plate out of 3/4" plywood. Drill the top part of the triangular plate to match the bolt pattern of the axle and attach the "skates" to the bottom of the triangular plate. Once home, take off the trailer wheels and bolt the "skates" to your axle.
Postby NightCap » Sun Jun 14, 2009 4:40 pm
Both good ideas. I guess the only way to make sure it will work would be to give it a go. See what happens. I like the idea of not having to take off the axle. But if you need the room you might have to...
NightCap
Images: 259
Postby len19070 » Sun Jun 14, 2009 5:54 pm
Hey, It beats flattening the tires then having to get your Sons entire Soccer Team to push it out.
Happy Trails
Len
len19070
Images: 24
Postby kennyrayandersen » Tue Jun 16, 2009 3:42 am
oops, so I posted to the other thread:
http://tnttt.com/viewto ... 820#529820
kennyrayandersen
Images: 38
Postby James & Avisia Flohr » Mon Jun 22, 2009 11:39 pm
Odd as it may seem, I too built 'a boat in the basement' situation. Mine, luckily, was only 2 1/2" too tall. Taking the wheels off was the trick. It rolls in and out on the hubs (Harbor Freight Trailer). If it's a standie, its going to be difficult to work on the roof in the garage, so rolling it in and out will help when that part of the project comes along. Jim
'Live, Love, Laugh and Be Happy'
