by Dale M. » Mon Jul 13, 2009 6:44 pm
Structurally round tubing probable has more strengths than square tubing.... however it probably makes little difference to trailer weighing in as to what a TD is.... And the cabin are you are making will add structural support to the frame.... Once you get past the above, the real issue is attaching the cabin (mainly the floor) to the frame..... If you drill through tubing it will weaken exactly where you do not it weakened on top of tube for compression load and bottom of tube where it is a expanding load..... Solution here would to have an appropriate number of tabs welded to frame to bolt floor to and then continue "the build" in traditional manner.....
I personally think it matters little if main frame is round or square tubing as long as overall design and tubing size is sufficient to support the "build"...
Dale
