angib wrote:Welcome, Adam - I must be fairly close to you (in Newcastle).
That tongue looks a bit weak to me, though I have no problem with the rest of the frame being that way round. A 1x2 tube (laying down) is about 80% as strong as two 2x2x1/8 angles, which is what some teardrops have, so we're not talking about anything extreme - though being only 35% as strong as the typical 2x2x1/8 tube makes it look a bit more scary.
I'm guessing from the photograph that your frame is 32" or 800mm from the front of the body to the centre of the ball. According to the Australian trailer design rules that would make your 1x2 tube sufficiently strong for a 340lb (155kg) trailer but my rule of thumb is that teardrops are abused much less than other trailers and so I think it's safe to double that rating for a teardrop.
Now 680lb (310kg) is light but not exceptionally light, so it wouldn't be hard to stay under that weight with careful building. I would be a bit worried that the tongue wouldn't be stiff enough (ie, too 'springy'), rather than not strong enough, but I must admit I've got no proof that it wouldn't.
A simple mod to really increase the tongue strength without adding too much weight would be to add a second 1x2 under the tongue, extending 16" (400mm) in front of and behind the front of the body (so a piece 800mm long).
Andrew
Hi Andrew,
Yes I work in Newcastle so must be very close
. Thanks for the advice, I may have to look at some kind of bracing to strengthen the tongue, although I was hoping that due to the weight balancing of the trailer (heavy stuff in the galley at the back behind the axle), I would never have more than 30kg on the ball/tongue when towing (
) and when the trailer is parked there will be no weight on the tongue at all, as I am fitting legs to the front bar of the chassis. Do you think this will be okay?
Adam
