asianflava wrote:Leaf spring with shocks is more complex but it is better if you go offroad. It has move articulation than a torsion axle.
A torsion axle would be a simpler setup.
Adding shocks to a prebuilt trailer is a good way to conrol the bouncing.
Shadow Catcher wrote:A trailing arm suspension should be better off road, witness the front suspension on my old Baja Bug which was cut and rotated. Speaking of which, has any one made a torsion bar axle adjustable? And has any one put airbags (to adjust height) or air adjustable shocks.
