donkro wrote:Thanks for the responses. The trailer does not sway so that's not the issue. It does seem that maybe the trailer is so light that it just bounces on bumps. Would switching to a torsion suspension solve this or should I just take a leaf out?
madjack wrote:donkro wrote:Thanks for the responses. The trailer does not sway so that's not the issue. It does seem that maybe the trailer is so light that it just bounces on bumps. Would switching to a torsion suspension solve this or should I just take a leaf out?
...unless you want the expense of changing out the axle, removing a leaf would probably work great...at the same time, you can get a aftermarket shock kit from Monroe Shocks which may help tame things as well.......
