Split-level Chassis
Split-level Chassis
Postby Prem » Thu Nov 12, 2009 9:51 pm
Now here's a great idea: a split-level chassis with a torsion axle:
With the torsion axle located right behind the welded overlap, I'll bet that is one long, strong chassis that doesn't have any flop in it even using fairly light steel C-channel or rectangular tube!
Great idea. Might have to do that on my next build!
Prem :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Carter » Mon Nov 16, 2009 6:31 pm
Prem,
I have one similar to that drawn up. The main advantage to me is being able to build it in the garage, Have 6'3" of headroom in the front of the standy and be able to slide it out under the 6'9" garage door header and bolt the axle on outside. I don't see any issues with strength.
I need a new Avatar. I'd put my dog up there but she doesn't look much like me. She's the skinny one.
Carter
Images: 32
Postby tinksdad » Mon Nov 16, 2009 8:34 pm
I thought I had seen a similar design recently; but I couldn't put my finger on it right off the top of my head (CRS temporarily raising it's ugly specter again). Then it came to me. Somebody from the forums asked me recently if I could down scale the Cabin Car in the Design Library for them. Although not as big as the one in your pic, the Cabin Car uses the same theory on the frame. I'm not an engineer; but it makes a lot of sense to me for that ground hugging appearance.
:applause:
tinksdad
Images: 155
Postby Prem » Mon Nov 16, 2009 8:43 pm
Carter,
What technique do you use to get the finished, heavy trailer up in the air to put the axle on AFTER you slide it out the garage?
Prem :thinking:
My goal...
Prem
Images: 144
Postby Prem » Mon Nov 16, 2009 8:46 pm
tinksdad,
Yeah, it's lower in the front where clearance is not needed as much as the rear by the height of the C-channel (4"?). But what's the advantage of a split-level for a cabin car's interior? (It's got less floor to ceiling height in the rear.)
Prem :thinking:
My goal...
Prem
Images: 144
Postby tinksdad » Mon Nov 16, 2009 9:43 pm
Personally I don't see the need for it in the Cabin Car either; but it's there if anybody wanted to look. I was just commenting on the similarity to yours. I'm a pavement only (or at least hard packed gravel at the minimum) traveler and really like the lower the better look. That's only my opinion.
Not my intention to start any kind of debate over it, so I'll just go back under my rock now and come back out when this passes. :lol:
tinksdad
Images: 155
Postby Prem » Tue Nov 17, 2009 1:10 am
tinksdad,
Oh don't go away. I never argue. I was just wondering. (I've never seen the Cabin Car's chassis.) I love finding out new ways of building things. I appreciate your input. :thumbsup:
Prem
My goal...
Prem
Images: 144
Postby Carter » Tue Nov 17, 2009 4:32 am
Prem wrote:Carter,
Prem :thinking:
Long pry bar under the corners and 2x4 blocks until it was high enough to use a floor jack and jack stands. Just inched it up. You'll see how strong the Torque Box is. My frame is very light and I was surprised it didn't flex at all
Jim
Carter
Images: 32
Postby 48Rob » Tue Nov 17, 2009 8:01 am
The cabin car trailers used a steel chassis slightly longer than the springs, which was bolted to the wood body.
The tongue was also a separate part, bolted to the body.
It did not use a full steel frame as most trailers did/do.
I'd never looked at the Cad drawings closely before.
They did not use a dropped frame as indicated in the drawings.
Rob
<img src="http://img.photobucket.com/albums/v284/1948rob/CABIN%20CAR%20PROTECTED%20IMAGES/cabincarframe1.jpg?t=1236087488">
48Rob
Postby Prem » Tue Nov 17, 2009 11:00 am
Rob,
Whoa! How long do you think it took for the wood between the tongue and the separate chassis to dry rot away? I'll bet the wood only lasted a few years before things started changing shape. Scary, eh?
Thanks for the photo.
Prem
My goal...
Prem
Images: 144
Postby 48Rob » Tue Nov 17, 2009 11:09 am
Prem,
Some had "moisture" issues while sitting in the factory parking lot waiting for a transport to deliver them to a dealer...
Most did okay though.
The real killer was water leaking in the top and sides, causing the body to weaken where the tongue support rods were attached.
A loose/weak tongue put many off the road before water damage to the floor/carrier chassis became an issue.
They were constructed of 1/4" plywood.
The plywood was held together with the 1x "ribs" similar to old airplane construction.
Very strong, and very light.
A good plan until it got wet...
Rob
48Rob
Postby Prem » Tue Nov 17, 2009 11:18 am
Rob,
Good grief. Sounds like guys working with wood for the first time and no understanding of semi-permanence.
I switched to an all aluminum cargo trailer conversion because I was so tired of wood maintenance issues and chassis rust issues on my teardrop and previous builds. No mo' issues, just camping.
Prem
My goal...
Prem
Images: 144
Postby aggie79 » Tue Nov 17, 2009 3:48 pm
Prem wrote:Carter,
Prem :thinking:
As seems to be the case with everything I do in life, my build has been somewhat out of sequence. Instead of picking wheels and tires first, I built the teardrop walls and floor, then had the frame constructed, and built a dolly to roll the whole thing around.
Later, I assembled the teardrop shell on top of the teardrop frame. Even with the weight, it rolls around very easily.
I later decided to change the tongue on the trailer and removed the shell. Once assembled, the teardrop body does act like a torsion box.
A pry bar, cheapo bottle jack, and cheapo floor jack is all it takes to raise and lower the frame/body.
:thumbsup: Geg'em, Tom
