by wannabefree » Mon Mar 01, 2010 11:21 pm
I have that frame and slid my axle back 4 inches from the factory position, about half the distance recommended by most builders. I am quite happy with the location I chose. My trailer is 5x10, so door clearance wasn't an issue. My tear is also higher than most, which moves the center of gravity forward a bit.
The nice thing about this frame is that if you don't build out over the wheels it is relatively easy to move the axle after you build it.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
