by dh » Tue May 11, 2010 10:45 pm
OR, if you really want to get into it, try some paint stripper. How in depth do you want to get into it? Will your walls hide the frame? Do you just need to do tongue? Just a few thoughts. I'b do what MJ said, just sand the paint down, and clean it up with Tide or oven cleaner, or engine degreaser. If you want a really shiny black, I'd go to bare metal, and sand it down with a 400 grit, prime it, sand to 600, prime again, wet sand to 800, then 1000, then shoot the black, wet sand to 1500, then 2000, then shoot the clear and buff it out. Buff1 (get it from Snap-On) is a really good bufing compound. It breaks down into halfs as you use it, so it automatically gets a higher grit with usage. Remember, the shinier black gets, the better the metal under it better be. It will show off every little tick turd under the paint.
