80/20 Extruded Aluminum
Postby johnohara » Tue May 18, 2010 8:44 pm
Has anyone here given consideration to using 80/20 extruded aluminum for constructing the cabin or for some aspects of the trailer (cross-members maybe).
This is an example of what I'm talking about:
http://www.amazon.com/80-20-1010-T-SLOTTED-EXTRUSION/dp/B001F0K4KA/ref=pd_sbs_indust_2
This stuff is very strong and could reduce the overall weight considerably.
Note: I don't work for them.
~John
johnohara
Postby starleen2 » Tue May 18, 2010 9:10 pm
Interesting :thinking: I wounder what would happen if you had to drill through it to bolt down a floor?
starleen2
5th Teardrop Club
Postby Ageless » Tue May 18, 2010 9:52 pm
We used tons of this at Boeing for making special carts and handling equiptment. For weight it's very strong. With all the specialized fittings, you can build anything
Ageless
Postby bobhenry » Tue May 18, 2010 10:46 pm
Looks pricey $$$$
I have seriously concidered commercial steel studs for the caboose when I start it. Old what's her name has her heart set on a 3/4 size caboose. It is to be built on my 8x20 flatbed double axle trailer. I think she has figured out that building trailers keeps me home and interfers with my dating. :lol:
Postby TD Beej » Tue May 18, 2010 10:52 pm
I looked into this stuff a little last year. It was pricey and I wasn't so sure the clamping system would be up to the task as a frame. If it were more cost effective it would be worth a test though. - Beej
TD Beej
Images: 74
Postby TD Beej » Fri Jun 04, 2010 4:12 pm
Anyone know how well this stuff takes to bending?
TD Beej
Images: 74
Postby mikeschn » Fri Jun 04, 2010 5:13 pm
It's not designed to be bent. But of course, with the right tools you can bend anything...
Postby TD Beej » Fri Jun 04, 2010 5:37 pm
I'm not thinking real sharp bends, things with radius generally in the range of feet, 90 degrees with 4' radius and such.
TD Beej
Images: 74
Postby Ageless » Fri Jun 04, 2010 5:40 pm
Without some high tech equipment (read 'stretch-forming) the cross section is going to distort
Ageless
Postby kennyrayandersen » Fri Jun 11, 2010 11:48 pm
I'm thinking that there are simpler, cheaper, easier ways of doing it :shock:
I'm more into the kiss method
kennyrayandersen
Images: 38
