by eamarquardt » Mon Jun 14, 2010 11:28 am
Given a saw, torch, and welder anything is possible. If you get the HF trailer for free or already have one on hand modifying it can make sense. If you buy one with modifying it in mind, I think you'd do better to build your own or have one built to your specs. Maybe a bit more but you get exactly what you want. If you network and find someone with a saw and welder a frame can be constructed in a day. 2BITS has set the standard for a simple well thought out frame built from two 24 foot pieces of tubing, having the metal yard cut them to 12 feet for transport, and ending up with only 4" of tubing left over!
Also, HF axles cannot be retrofitted with brakes easily (if at all, but anything is possible if you throw enough time and money at it).
Gus
