Replacing HF axle with Dexter
Postby wannabefree » Sat Aug 14, 2010 8:05 pm
Ok, this is not about whether HF is a good or bad trailer, but if you should just happen to have an axle with a bent spindle, like I did :x , here's one way to fix it.
I bought a Dexter 56 inch 2000 lb axle, hubs, bearings, spring saddles, U bolts, and plates ($250). Seemed like a good fit; the HF axle was 56-1/4 inches. Unfortunately, the spindles on the Dexter are longer, making for some interference with the springs. I managed to (just) get the axle on by straddling the flange on the spindles with the spring saddles. It is solid, but I would recommend the 58 inch axle to anyone else doing this.
The Dexter axle is cambered, unlike the HF. It should be hung with the camber up, so the wheels toe in at the bottom. To find which side goes down, mount the hubs and set the axle on the driveway. Rock it around - - the axle will settle with the curve down. Mark a line the length of the axle on the top side with a lumber crayon. This line goes down when you hang the axle.
The Dexter is a much more solid axle (thicker, heavier), as are the U bolts and plates. You will need to oval the holes in the Dexter plates, as the HF springs are wider than Dexter planned for and that's the only way to make it fit unless you want to grind away some spring. Ovaling the holes took a couple hours with a file and dremel; not fun. It might actually be easier to make your own plates. You can't reuse the HF U bolts as they are too short. Alongside the Dexter U bolts the HF parts are just plain flimsy, anyway. You don't need to weld the spring saddles unless you have brakes.
Now. lift, shove, torque, swear, bust knuckles, swear some more, put on a little Locktite, and torque some more. You'll know when you're done.
I am pleased with the result. The trailer, already high, now rides about an inch higher, thanks to the beefier axle and thicker spring saddles. The cost of my $270 trailer is now up to about $800, about par with a real trailer if my time is worth nothing. Some things you just have to learn the hard way. Oh, yeah, this isn't about whether HF trailers are any good or not. :lol:
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby dh » Mon Aug 16, 2010 8:42 pm
So, no plans to upgrade from the slipper springs?
dh
Postby wannabefree » Mon Aug 16, 2010 10:31 pm
I thought about that when I was spending hours filing holes in the u bolt plates, but no, the springs seem adequate. Is there an advantage to the other kind of springs, whatever they are called?
wannabefree
Images: 82
Postby dh » Wed Aug 18, 2010 10:40 pm
If you like how the slippers are performing, then I wouldn't bother. Shackles don't make as much noise though.
dh
Postby Alphacarina » Thu Aug 19, 2010 9:44 am
I put a Reliable (Northern Tool) 2000# straight axle under my HF 1740
I had to cut the spring perches off the axle and weld them back on at the correct width - No dimension on the Chinese HF trailers is anywhere near 'standard'
The 2000# axle uses a standard 1 inch spindles, which is considerably larger than the HF unit - No doubt they are much stronger
I kept my axle on top of the springs (like I had done with my original build) to keep the trailer height low
I wish I had done this sooner - The bent HF axle cost me a good set of tires ;)
Actually . . . . I wish I had spent a little more and bought a real trailer before I begain building - Like you, I discovered too late that it would have actually been cheaper in the long run :(
Don
Alphacarina
