Steve_Cox wrote:1/4" in the front corners isn't much to worry about. As you clamp, glue, and bolt the structure on, it will conform quite a bit. A quality construction adhesive/sealant will make small gaps disappear. With my teardrop I went through that angst and heated and tortured the frame into submission and got it within 1/10" in level, (while sitting on jack stands) Only to find lumber irregularities caused gaps greater than that at a couple of places during final assembly of the walls to the trailer. Bolts and construction adhesive made the gaps disappear.
doug hodder wrote: Getting the frame square in the horizontal plane and squaring the axle to the hitch point is much more important, you can live with the 1/4".
