Axel posistioning
Axel posistioning
Postby Early 1 » Mon Jun 11, 2012 5:49 am
I have to put a new set of springs on a utility trailer that I purchased. I had to use new hanging brackets etc. because of different spring length.
While placement front to back is no problem, what is the best way to fiquire where the axle should set ? Can measuring from sidewall of the tire to frame on both sides , front and back work? In other words, making sure it's not tracking weird..toe in etc.
Thanks :thinking:
Early 1
Re: Axel posistioning
Postby sdtripper2 » Wed Jun 13, 2012 11:30 pm
Early 1 wrote:I have to put a new set of springs on a utility trailer that I purchased. I had to use new hanging brackets etc. because of different spring length.
Thanks :thinking:
Early:
You can go here for much information on axle placement:
viewtopic.php?t=11178
More specific to your question Read this thread:
viewtopic.php?t=12747
sdtripper2
Search Garoux
Images: 168
Postby Early 1 » Fri Jun 15, 2012 1:10 pm
Thanks guys. Great links :thumbsup:
Early 1
