Don't know anything about it, such as is it a good, or bad design, but it is interesting.
Appears to be a 4 x 8 sheet of plywood.
Rob
angib wrote:What I find interesting about that frame is that the tongue is mostly just attached to the front of the body and only slightly to the main X-frame.
And the main X-frame is just carrying the load from the springs out to the sides of the box.
It's got a sort-of semi-monocoque/unibody thang going on.
Nobody wrote:At the front 'rail' there are only 2 similar size bolts either side of the tongue, through the floor, the horizontal rail flange, & through a steel 'strap' under the tongue in a sort of clamping arrangement.
