Trailer balance point place axle or wheel centre?
Postby webbaldo » Thu Feb 21, 2013 2:07 pm
Hi there,
Ive found the ideal position for my required weight distribution by making a giant seesaw of my teardrop with some bricks and a scaffold pole.
Now my question is, i've found the point on the chassis where i'm happy of the 'sweet spot' weight distribution point.
so... do I fit the axle directly on this line (point), or so I fit it so the hub centres are over this point?
to try and explain things better this 'point' i'm on about is the exact location on my chassis (about 40% from rear) where im happy with the nose weight etc. Its not the actual trailer balance point.
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Re: Trailer balance point place axle or wheel centre?
Postby bobhenry » Thu Feb 21, 2013 2:23 pm
From the balance point move rearward approx 20% of the body shells lenght. This will give you enough tongue weight to give the trailer better towing manners.
Also the further rearward the better the backing manners your little trailer will have.
Postby webbaldo » Thu Feb 21, 2013 2:39 pm
bobhenry wrote:From the balance point move rearward approx 20% of the body shells lenght. This will give you enough tongue weight to give the trailer better towing manners.
sorry my fault for not describing it properly
I didnt mean balance, I mean ive found the ideal 'point' where the right weight is distributed (ie. my nose weight is spot on etc) its roughly 40% from rear.
Would I mount the axle here, or mount the axle so the wheels are over this point?
webbaldo
Postby Fishingtomatoseed » Thu Feb 21, 2013 2:45 pm
If your point is where you have the correct tongue weight that would be the center of the axle. Your mounts for the leaf spring will be forward and behind your points.
Fishingtomatoseed
Images: 9
Postby eamarquardt » Thu Feb 21, 2013 2:47 pm
Hi,
Your spindles should be centered over the spot that gives you the weight distribution that you desire. With a conventional axle the axle (crossmember) and spindle are in alignment. With a torsion axle the cross member is fwd of the spindles. Just focus on spindle position not crossmember position.
Hope this helps.
Gus
eamarquardt
Images: 150
Postby webbaldo » Thu Feb 21, 2013 3:29 pm
eamarquardt wrote:Hi,
Hope this helps.
Gus
Thanks for the reply, im using a torsion axle as you mentioned, not leaf springs, there a bit ancient tech lol!
webbaldo
Postby oicu812 » Sat Feb 23, 2013 10:34 am
The axle is carrying the load, the trailing arm transfers the load to the axle, no matter how long the arm is the axle is still your pivot. I think that's what your asking.
Pie are square?
oicu812
Postby Steve_Cox » Sat Feb 23, 2013 10:55 am
Webaldo,
Simple answer to your question. Wheel Centers.
Over the years of discussion about weight distribution for tiny campers, I have learned that in Europe tongue weight tends to be about 10% of the loaded trailer weight, but in America it is usually 15 to 20%.
Steve_Cox
Images: 196
Postby eamarquardt » Sat Feb 23, 2013 1:44 pm
oicu812 wrote:The axle is carrying the load, the trailing arm transfers the load to the axle, no matter how long the arm is the axle is still your pivot. I think that's what your asking.
It may be the pivot point of the suspension system but it is not where the frame sees the axle supporting the frame, i.e. the fulcrum.
Steve_Cox wrote:Webaldo,
Wheel centers = spindle centers. Samo, samo.
Gus
eamarquardt
Images: 150
Postby aggie79 » Sat Feb 23, 2013 1:52 pm
Hope this helps.
Gus
I'm with Gus. The fulcrum point is spindle centerline regardless of the type of axle.
Postby webbaldo » Sun Feb 24, 2013 9:48 am
Hope this helps.
Gus
cheers for all your answers, after reading your replys and several on a boat building forum, they all say wheel centres!
webbaldo
Postby oicu812 » Sun Feb 24, 2013 10:41 am
Uncle,
Good points. I'm leaning towards Gus now. Thanks for the insight, I think an experiment is in order.
Pie are square?
oicu812
