Wheels for the NT trailer
Postby jeporter25 » Tue Mar 12, 2013 9:15 pm
Does anyone know if these wheels will work on the Northern Tool 5x8 trailer http://www.vintagetrailersupply.com/13_ ... ts-547.htm ? I sure think that they would look sweet with those dome type hubcaps.
jeporter25
Re: Wheels for the NT trailer
Postby les45 » Wed Mar 13, 2013 6:10 am
Yes, that wheel will definitely fit your NT trailer. I recently bought the same size wheel in a white spoker and it fits fine on my NT 5X8. The only thing you will have to watch is your choice of tire. With the 1/2" inset on the wheel, you will need to measure your overall tire width to make sure it will not rub the frame. A 155 or 165 should work fine. A 175 will be less than 1/2" from the frame.
les45
Images: 605
Postby jeporter25 » Wed Mar 13, 2013 11:14 am
Thanks les
jeporter25
Postby jeporter25 » Wed Mar 13, 2013 11:15 am
I figure that I can use the stockers for spares
jeporter25
Postby les45 » Wed Mar 13, 2013 12:11 pm
jeporter25 wrote:I figure that I can use the stockers for spares
that's what I did; no need to buy a third wheel and tire
the 12" is a little shorter than the 13" so I kept both 12 inchers to use as a matched set for spares just in case (especially if you still have a long way to go)
I throw my spare in the back of the TV so two don't really take up that much more room than one
les45
Images: 605
Postby mikerueve » Wed Mar 12, 2014 8:57 am
Isn't the center hole on that wheel 2 1/2"? I thought that the center hole on the Northern tool 12 inch wheels was 3 inches. The reason I ask this instead of measuring myself is that we are in the process of having ours built and I am trying to figure out a way to incorporate baby moon hubcaps. Those wheels are the only 12 or 13 inch wheels I've seen that have the proper "nodules" to pop that baby moons on.
mikerueve
Images: 30
Postby les45 » Wed Mar 12, 2014 10:15 am
On my two year old NT 5X8, the hub diameter is 2 1/2" and the center hole on the stock 12" wheels is 2 13/16". The opening on my 13" wheels is 3 1/4".
les45
Images: 605
Postby mikerueve » Wed Mar 12, 2014 11:38 am
Thanks for the info! Once I get the trailer, I'll definitely eyeball the hub myself. I'd love to use the wheels listed above!
mikerueve
Images: 30
Postby MtnDon » Wed Mar 12, 2014 12:27 pm
Keep in mind that trailers usually use lug centric mounting unlike cars/trucks that use hub centric mounting.
That means the center hole does not matter on a trailer as long as it goes on. . With lug centric the wheel hole does not fit snugly; the lugs center the wheel and support the load.
MtnDon
Images: 24
Postby les45 » Wed Mar 12, 2014 3:35 pm
mikerueve wrote:Thanks for the info! Once I get the trailer, I'll definitely eyeball the hub myself. I'd love to use the wheels listed above!
I would definitely measure the hub diameter before buying wheels. I've found that the dimensions on these Chinese trailers can vary from one trailer to another even within the same brands.
les45
Images: 605
Postby mikerueve » Wed Mar 12, 2014 4:48 pm
Don't worry I will. Lol, the gentleman who's constructing my tear has a heart of gold and I've already thrown all of the custom options at him that I think is prudent. It's going to be a beautiful rig and I'm going to leave him alone the rest of the way.
Once I get it, I'll take a hard look at the wheels. I really want the baby moon look to complete it. I may even try to "rig" something with the stock Norther Tool wheels. It's all a process anyways. Gives me something to play with...
mikerueve
Images: 30
