Side rails...
Side rails...
Postby Blaze45 » Fri Jun 07, 2013 8:22 pm
I saw somewhere where angle was welded to the side rails of a bolt-together frame. Has anyone done this?
Thanks...
John
Blaze45
Titanium Donating Member
Re: Side rails...
Postby working on it » Sat Jun 08, 2013 9:32 am
For what purpose? to outline and secure the wooden flooring? I considered doing that, but decided that the extra weight added was too much, water and dirt could accumulate in the space between angle and floor, and that the flooring itself (when bolted/tek screwed to the frame) would be strong enough to strengthen the frame itself. And once the upper box was added, much stronger still. Even so, I used steel corner braces all around, and gusseted angle braces away from corners. And PL adhesive to cement the deal!
173193172890148599
working on it
Images: 457
Re: Side rails...
Postby Blaze45 » Sat Jun 08, 2013 10:12 am
The addition of the angle was to support the rails...seems like added, unnecessary work to me. From what I have read on the forum, the floor should take care of that. Thanks for the reply.
Blaze45
