Mary C.
angib wrote:I see two ways of doing an all-wood tear:
2) The 'smart' route is to recognise that a self-supporting teardrop body doesn't need any frame under it - though it does need a secure axle mount plus a tongue. I see no problem in building enough strength into the base of the sidewalls to allow an axle to be bolted on, so that just leaves the tongue. This can be built in box-section plywood to connect to the front of the teardrop body.
Here's a design I did a long while ago, showing a nearly-all-wood Ultralight. Blue is wood, red is the few bits of metal needed (though with care even those could be eliminated and replaced by some oak) and green is the purchased hardware.
But building an all-wood tear is a lot, lot harder than building a metal-frame one, so no-one should think it was an easy alternative to some welding. And I'm not convinced that it would be safe to do this, unless the builder had wood-epoxy boatbuilding experience.
Oh, and doing this without using epoxy strikes me as nearly impossible - this would not be just woodworking in the normal sense of cabinetmaking - a different skill set would be required.
