Steel wheels
Steel wheels
Postby Kim Armstrong » Sat Aug 24, 2013 10:26 pm
Who is a good source for regular 14" steel rims. Not the spoke type. Thanks.
Kim Armstrong
Re: Steel wheels
Postby Irmo Atomics » Sun Aug 25, 2013 5:20 am
Bob
Irmo Atomics
Images: 64
Re: Steel wheels
Postby eamarquardt » Sun Aug 25, 2013 9:04 am
Not sure what you're looking for and I don't see wheels on the web site but it might pay to call:
http://www.hubcapmike.com/
Hope this helps.
Gus
eamarquardt
Images: 150
Re: Steel wheels
Postby Kim Armstrong » Sun Aug 25, 2013 11:54 am
Thanks all. Looking for some plane auto type steel wheels in 14x5. Most of what I 've seen are the spoke type like HF or NT uses.
Kim Armstrong
Re: Steel wheels
Postby danlott » Sun Aug 25, 2013 12:25 pm
Hoplite Traveler Build thread
danlott
Images: 264
Re: Steel wheels
Postby Treeview » Sun Aug 25, 2013 12:27 pm
Go down to your local tire store. Everywhere that I've lived they've had plenty of spares.
Or go to a salvage yard. You'll need to know your bolt pattern dimensions.
http://www.etrailer.com/faq-wheel-bolt-pattern.aspx
If you measure hole to hole don't try to find the centers. Measure from one side of one hole to the same side of the adjoining hole...same dimension as measuring centers but it's fixed.
Treeview
Images: 30
Re: Steel wheels
Postby kludge » Mon Aug 26, 2013 9:06 am
Have you looked a temporary spares? Pretty cheap at scrap yards, then pick whatever hub caps you like.
I have a pair temporary spares (15x6, 5 on 4.5") from a Jeep Cherokee that I'm holding on to for a trailer build.
kludge
Re: Steel wheels
Postby Kim Armstrong » Mon Aug 26, 2013 8:25 pm
Thanks everyone. I think I may have found a pair.
Kim Armstrong
