Welding questions
Welding questions
Postby 48Rob » Fri Jan 17, 2014 6:39 pm
Can I use 309-3091 for welding mild steel?
Will the stainless cause a problem for the welder who will be coming later to do the real welding on the trailer frame ?
(I'm just tacking things together)
I have a large amount of the rod that is doing no good sitting in a drawer...trying to be frugal...
Rob
48Rob
Re: Welding questions
Postby Redneck Teepee » Fri Jan 17, 2014 7:33 pm
Yes you can, in fact 309 is rated for joining carbon to SS
Redneck Teepee
Images: 21
Postby 48Rob » Fri Jan 17, 2014 7:35 pm
Thank you.
I read than on the package, but wanted to be sure it wouldn't cause a problem unforseen to me...
Rob
48Rob
Postby Redneck Teepee » Fri Jan 17, 2014 7:55 pm
Rob, just about any welding process you choose will go right over your tacks, just be sure and grind them a little first as with any tacks. A 70-S hard wire which is pretty normal in a MIG application won't even know they are there.
Redneck Teepee
Images: 21
Postby ctstaas » Tue Mar 25, 2014 4:22 pm
Hay 49rob, In my experience it's acceptable to weld mild steel with stainless wire. It could require more effort to grind your welds and drilling through a weld might not be practical. Ihe up side is your welds will be rust resistant. I have welded stainless material with mild steel wire and had a slight loss in stainless properties at the weld.
ctstaas
Postby 48Rob » Tue Mar 25, 2014 5:38 pm
Thank you.
It is harder to grind, but looks pretty and doesn't rust!
Rob
48Rob
