So I have searched for a while and can't find any information on this, either in tnttt or elsewhere. I have a Harbor freight trailer that has most of a teardrop floor built on it. I just got access to an axle from a wider travel trailer that has brakes on it. The new axle is roughly a foot wider than the HF axle. Can I switch the axles and use the one with brakes on my teardrop? It would require some modifications to my build, mostly having outboard fenders instead of the wheels underneath as is currently the case.
I do not know the weight rating of the new axle but the trailer was an old (60s?) style trailer about 12-15ft long. So I think that it would be a lot stronger than the current HF axle. Would the extra strength be enough to make up for sticking 6 inches or so further out from the frame? it seems the wider wheelbase would make the trailer more stable and I would dearly like to have those brakes, but I can't stop wondering about the distance from the wheel to the frame and if it might be a problem.
Is this a dumb idea? Would it be safe to do this? I am kinda in the dark on this one, so any input welcome.
