I'm getting ready to place an order for a Dexter axle to replace the leaf spring axle on my Harbor Freight trailer. While figuring out the measurements and whatnot, it looks like I need to supply the mounting bracket width as well as the hub face width. If I specify the hub face width to be a bit larger than normal, does this mean I'll receive a longer axle (still with the right bracket location) which will give me a bit more room to widen the bed of my teardrop without needing to notch out space for the tires?
What impact would this have on the stresses on the axle itself? It it safe, common, recommended? The main reason I'm thinking about this is that I really need the interior to be at least 4 feet wide. with 1" thick walls, my 4 foot wide trailer is only 3'10" inside. If I added 3"-5" of axle length that would give me just enough space to widen the trailer to be a bit over 4 feet wide inside.
