les45 wrote:It's not just the springs. The stiff trailer tires and high tire pressures are half the problem. I had a similar problem with my weekender bouncing like that and it weighed 1,100 lbs on a 2,000 lb GVW NT 5X8. I dropped the tire pressure from 60 lbs to 40 lbs and no improvement. I finally changed out the 5.30X12 Chinese trailer tires for some 175-70R13 passenger car tires and it made a world of difference. The softer tires virtually eliminated the bounce without changing springs or adding shocks. There have been several posts on this subject on the forum and, if I recall, the conclusion was that eliminating leaves from the springs didn't really help that much.
Dale M. wrote:60PSI in tires....... That is way to much!.......
And removing leaves will reduce weight capacity but will also soften up spring rates....
Dale
Cantputt wrote:
60psi is what the tire is designed to run at.
Yes, removing leaves will reduce capacity. That is the point, I have a 1720lb capacity trailer only hauling 500lb.
