Grease Cap Installation Tool
Postby absolutsnwbrdr » Thu Apr 03, 2014 8:15 am
I hate grease caps. They never seemed to be tooooo hard to put on my Harbor Freight hubs. But my Dexter hubs seem to be much more difficult!! Botched up 2 grease caps trying to replace the dented ones that came with my new axle.
So I went to Lowe's and dug through the plumbing aisles until I found two cheap pieces:
a 1.5" cleanout plug and a 2" x 1-1/2" bushing (threaded)
(assembled on the left, pieces on the right)
Screw the cleanout plug into the bushing and you have yourself a nice compact grease cap installation tool, for the pricey sum of $1.70.
Should work for most 2000-3500lb rated hubs (with the 1.98" dust caps, which I believe is standard for small trailers).
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: Grease Cap Installation Tool
Postby Redneck Teepee » Thu Apr 03, 2014 9:05 am
I always say..."It's only a stupid idea if it doesn't work". Good thinking... I can relate to the problem you solved. :thumbsup: :thumbsup: :thumbsup:
Redneck Teepee
Images: 21
Postby Dale M. » Thu Apr 03, 2014 9:38 am
For the grease/dust caps I work with (VW) a section of 2 inch ID, ABS works well.... Never though of coupling and plug... Good upgrade over my tool....
Dale
Dale M.
Images: 18
Postby 48Rob » Thu Apr 03, 2014 6:41 pm
Nice job! :thumbsup:
Rob
48Rob
Postby Kullas » Fri Apr 04, 2014 7:35 pm
My tool of choice is a rubber mallet
Chris
Kullas
