Northern Tool 5 X 8 Question
Postby Starseeker » Wed Apr 30, 2014 8:09 am
I got a question about Northern Tool's Ironton Heavy Duty 5 X 8 trailer. According to the website the side rails are channels that are 1 1/2 wide, 3 3/16 high and 8 feet long. Now could you change these side rails out and use the same size channel that is 10 feet long to convert it to a 5 X 10?
Aaron
KF5VBV
Starseeker
Images: 10
Re: Northern Tool 5 X 8 Question
Postby MtnDon » Wed Apr 30, 2014 9:02 am
Finding steel that size might be the problem.
It may be easier to extend the tongue. Add a center member that extends from the second or third crossmember back from the front through the point of the "A" and forward a couple feet. That would permit building forward over the A-frame. Then move the axle as needed / if needed.
he way the tongue in made you can flip the "plate" the the coupler mounts to. Turn it upside down and you can run a square tube through the plate and under the a-frame and main frame. Of course that added square tube must be sized adequately for the load.
I have done that for an ATV / utility flatbed trailer and might be able to find some old pictures, if I took any. If not I can take some pictures this coming weekend and post them next week.
MtnDon
Images: 24
Postby absolutsnwbrdr » Wed Apr 30, 2014 9:43 am
Yup, what MtnDon said. You can easily build out over the ends of the trailer frame. My X-Cubed's overall length is 126", on the NT 5x8. It's built out 18" over the tongue, and extends out 12" in the rear. Just add wood supports that go from side wall to side wall and let your extended floor rest on those. I did extend the tongue.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Starseeker » Thu May 01, 2014 2:45 pm
Ok thanks for the replies. I think that i have settled on the Cub profile in the Design Resources section. From the looks of it, the cub looks like a 10 foot TD on an 8 foot trailer. If that is the case all I would have to do is extend the tongue to make up for the overhang.
Aaron
KF5VBV
Starseeker
Images: 10
Postby bobhenry » Fri May 02, 2014 6:18 am
This one was a Namco ( I think ) bought it used from a buddy. Image
After a little sawsall action and some barn building it looked like thisImage
Note the shove 2 foot forward to make a 10 foot trailer on an 8 foot foundation
The 2x2 x3/16 tongue proved to be a bit anemic and later had to be trussed for strength a 2 x 3 tube would have been a better choice.
Here is a shot of the trussed tongue a flat strap was added like a bow string to tension under weight made a good repair to a design boo boo !
