Please look at the attached picture. It is of the tire that I finally removed from our teardrop near the end of our Route 66 trip. The tire had approximately 4500 miles on it at the time I swapped it out. It was part of the set that was shipped with the original Northern Tool trailer. It was on the passenger side of the trailer. The tire on the driver's side survived the entire trip with tread remaining (it has roughly 6500 miles on it now). These tires are 12 inch, 5.3 width. The tires were inflated to 60 psi. I think they are rated for 80 psi. There doesn't appear to be any pronounced camber on either side of the trailer that I can see. The trailer tows straight and there is no fish-tailing that I noticed. I was careful to evenly load the items that were carried in the trailer. If anything there would have been a slight bias toward the Driver's side due to the positioning of my battery.
During our trip, the vast majority of our time was spent on the original alignments of Route 66(whenever we could find it). The old two-lane roads do have more of a pronounced crown than modern roads. I'm wondering if this could have contributed to this type of wear. By this I mean the trailer "leaning" more to the outside, or passenger, side. The only thing that makes me dubious of this is the fact that there appears to be tread left at the very outside of the tire.
Anyways, take a look and let me know what you think. Should I look at getting a "better" quality trailer tire? If so, what are your reccomendations? Also, I'm considering going to a 13 inch wheel/tire setup. It seems that a lot of people are of the opinion that you can get a higher quality trailer tire in that size. Is it worth it?
Thanks in advance for any help.
