I think I've settled on a 5x10 trailer that will hold a ~6x12 camper. I haven't had much luck finding a used trailer for a decent price so I'm going to contact a couple welders and fab shops to get quotes for a custom frame. I've taken DMcCam's frame design and modified it for my dimensions.
The camper walls will be built using 1x2s, 1/8th plywood, and foam board. The floor will be 1x3s, 1/2in plywood, foam board, and linoleum.
TV is a 2011 Silverado 1500 4WD w/towing package.
Reference Material:
http://www.vulcaniavolunteers.com/TEARD ... _FINAL.jpg
viewtopic.php?f=35&t=35097&start=45 (2nd to last post contains frame pictures)
My design:
2x2x1/8th angle for the cross members, 2x2x1/8th square tube for frame and tongue.
Where I'm stuck:
1) Axle placement.
I haven't been brave enough to try the spreadsheet method of figuring out where to place the axle. I've used the 40/60 rule. How critical is axle placement, do inches matter or is a ballpark good enough? It seems like a lot of people just get the HF kits and go with the stock setup so I don't think it is too critical.
2) Stabilizer selection and mounting.
After reading the forums a bit I think I've settled on BAL Light Trailer Stabilizing Jacks (http://norcoind.com/bal/products/consum ... jack.shtml) 2 in front and 2 in back. Is that too little or too much? Should these be mounted directly to the front and rear frame or at a 45 degree angle like on DMcCam's design?
3) Tongue Jack placement.
Most of the trailers I've seen here have the jack mounted on the side of the A-Frame (vs inside the frame directly behind the coupler). Is there a reason for this or is it just preference?
4) Crossmember and body brackets.
I added another cross member and 2 more body mounting brackets when I scaled up the design. Are these overkill?
5) A-Frame and Tongue
I completely guessed at this. I made it 4ft long and added some brackets for possibly mounting a storage box. Are there any critical measurements in this area?
