stub torflex axles
stub torflex axles
Postby dave powell » Wed Jan 21, 2015 12:10 am
Just wonder has anyone used the stub type torflex axles, local store here has 2000 lbs units at 22.5 start angle for $119.99 each. I believe there made by Rockwell.I have looked thru this site and haven,t found any mention of them being used. Thanks Dave
dave powell
Re: stub torflex axles
Postby Dale M. » Wed Jan 21, 2015 8:53 am
Quite a few builds bases on this type of axle.... You just have not found a build thread.... Try different search criteria when looking....Its possible you are using incorrect product name or description in search...
Dale
Dale M.
Images: 18
Postby lrrowe » Wed Jan 21, 2015 9:01 am
Try keying in this string in Google for a list of links.
rockwell site:tnttt.com
Here is one for example of the results.
viewtopic.php?t=50803&p=941622
It is a great method to search for links in tnttt.com or any other site for that matter.
Another great tip learned from this forum.
Bob
lrrowe
Images: 439
Postby tony.latham » Wed Jan 21, 2015 9:58 am
They've been used on this forum. Torflex is Dexter Axles brand name for their torsion axle and they are not a Dexter product so don't use that for a keyboard search.
Postby alaska teardrop » Wed Jan 21, 2015 9:09 pm
Hi Dave,
Here is the Rockwell website: http://www.rockwellamerican.com/products
At a quick glance, it looks like their torsion axles are similar to Dexter in that you can order different weight capacities & start angles, ect.
Be careful to match the axle capacity to your loaded trailer weight (i.e. a 1000# trailer with a 2000# axle will ride very rough). And also be aware that the start angle determines your ride height.
In addition, half axles require different frame mounting & alignment considerations than a beam type torsion axle.
Two threads to study: viewtopic.php?f=35&t=14125 &
viewtopic.php?f=35&t=7214
Good luck with your build & be sure to post pics.
Fred
alaska teardrop
Postby Jiminsav » Sun Feb 22, 2015 10:31 pm
try the term half shaft.
Jim in Savannah
Jiminsav
Images: 40
