Bolt Spare Tire Under Floor 3/4" Plywood
Postby garywi » Thu Feb 12, 2015 9:57 pm
Hey Guys, I see some with the HB trailer mount the spare 12" tire under the trailer, to the plywood floor, using carriage bolts. Anyone have an issues with this staying put, or the carriage bolts ripping through the plywood. Thanks!
garywi
Re: Bolt Spare Tire Under Floor 3/4" Plywood
Postby Redneck Teepee » Thu Feb 12, 2015 10:04 pm
Add a 16 ga. backing plate on top and it will never go anywhere under normal use.....just my 2 cents worth. :D
Redneck Teepee
Images: 21
Postby Jerry Bleeg » Fri Feb 13, 2015 4:29 pm
I mount mine under the floor. I have a 1/2" floor and added. A 5/8" spacer to increase the thickness to 1 1/8". I've had no problems. There may be a pic on my gallery.
Jerry Bleeg
Images: 48
Postby ctstaas » Mon Feb 16, 2015 11:15 pm
My '83 GMC has a spare tire holder that slides out from underneath when needed and if I were to mount mine under I would search wrecking yards for something similar. My spare is mounted on my tongue.
Enjoy, Chris
ctstaas
