Leaf springs
Leaf springs
Postby Da'engineer » Sun Mar 22, 2015 7:52 pm
On the axle for my trailer I need to move the leaf springs out farther then the recommended center on the axles. Has anyone done this before?
Da'engineer
Re: Leaf springs
Postby KCStudly » Sun Mar 22, 2015 10:55 pm
Out toward the hub?
The limit will likely be tire sidewall clearance with the frame or cabin wall, but the manufacturer's spec.'s are probably there for a reason. I would want to know more from them before going outside their bounds, especially if you are anywhere near the rated capacity. Remember that leverage can have a rapid effect on the forces involved.
It may also be that it is just not practical to get a good weld on the spring perch if it is too close to the brake flange.
